jwong84
Sep 10, 2015Aspirant
R7000 2.4ghz not working but 5ghz is fine
Firmware 1.0.4.30 and 1.0.4.28 tried for weeks at a time.
Wireless devices connected to 5ghz band are all working perfectly and have been since i purchased this router at the beginning of June ...
- May 25, 2016
Good news! We now have a production version of firmware that should resolve the 2.4 GHz issue, v1.0.5.64. You may download this firmware from our R7000 page here: http://downloadcenter.netgear.com/en/product/R7000#searchResults
As IrvSp correctly notes, this version of firmware fixes the 2.4 GHz issue and reinstates the new features, such as Kwilt, Smart Connect, and WiFI Transmit Power Control. It does not support Arlo. We hope to have a beta version that supports Arlo in the next two weeks.
We welcome any feedback you provide on this new firmware, and appreciate your patience as we resolved these issues. Thank you all for supporting the R7000 and NETGEAR!
lrubio
Feb 05, 2016Aspirant
The firmware version Netgear sent to me did not work for me. The firmware version I cited above did work for me. The only way to determine if it will work for you is to try it.
I was really happy with my router's performance prior to the latest firmware update. As we know, the new update goofed things up for us or we wouldn't be on this thread. So, reverting back to a firmware version that worked was a no brainer for me. My router is again working great and I'm again happy with it.
I wanted to share my experience and results in the event it might help someone else as this can be a very frustrating experience.
Larry
JRapp
Feb 06, 2016Aspirant
Ditto for me, i.e. nothing but problems with 2.4GHz connections since updating to recent version(s) of the R7000 firmware. Reverting to 1.0.4.30 via the Netgear download site appears to have fixed that.
LIke many of us on this thread, I'm upset by what I see as Netgear's cavalier attitude toward their customers. Releasing a firmware update that causes this problem for so many customers is bad enough; the subsequent delays in identifying, acknowledging and offering a resolution just make it worse.
- oertjeFeb 06, 2016Aspirant
I have also downloaded 1.0.4.30 and it seems stable and better
But something strange: Arlo is as netwerk but in the router genie I cannot find a thing about arlo for how to switch off
- JamesGLFeb 06, 2016NETGEAR Employee Retired
Hi oertje,
Please reset the router to factory default after reverting it to 1.0.430.
Hi All,
All issues for the latest firmwares has been forwarded to engineers and working for a fix. We will provide an update once new firmware is available for release.
JamesGL all well, but now it works great without portforwarding again, so i take arlo for benefit wifi works great now so in the mean time no upgrade anymore I have learnd my lesson en when my router ever gets broken, no netgear anymore,
You are losing customers, so bad is the aftersale. and anyone that will hear I talk about.
Sorry, but is your own fault bad advertising cost your company millions
- rpoffenFeb 06, 2016Virtuoso
It seems that after changing the FW, either up or down, particularly between 1.0.5, 1.0.6, and 1.0.4, that a hard reset to factory defaults, followed by a manual reconfigure has helped a number of people.
Note that this is NOT the same as simply power cycling or rebooting. You can erase the settings to factory defaults by logging in to the WEB GUI, clicking on the "Advanced" tab, selecting "Administration" in the left hand pane and then "Backup Settings". On that page, click "Erase" and follow the prompts.
Alternatively, you can use a straightened paperclip to press the button through the hole in the back of the router. Keep it pressed (with power on) for at least 10 seconds until the LED light flashes.
After this, it should be as if it was bought new, and you will have to go through the configuration process. Do NOT restore a saved config. As near as I can tell from analyzing the backup file, it is a binary file that is probably an image of the configuration database memory. As different FW use different areas or have a different layout of the database, then it seems certain settings can "leak" between versions. This is evidenced by reports of some people reverting back to 1.0.4.x from 1.0.6.28 and seeing SSID's with "Arlo" in them, even though 1.0.4.x did not have Arlo support.
- NiferFeb 06, 2016NETGEAR Employee Retired
LeeH, great idea, let me talk to engineering. I agree that our email campaign to encourage adoption of the new firmware has exacerbated this, and I apologize for that.
Oertje, it sounds as though you may have a unique issue. Do you have screen shots or logs that you are willing to share? We could all benefit from understanding what you're seeing. Thank you!
And tn77, I agree with you. In late November, we added a new tool to our community that should help us identify emerging issues in the community more quickly, so that we can engage engineering earlier. We hope this will avoid similar situations in the future. But I'm sure all participants in this thread appreciate your highlighting the issue!
versie 1.03 is ook not stable.
truck with the paperclip I gues
Why is there no solution,
- oertjeFeb 07, 2016Aspirant
JamesGL it seems Ok the reset with paperclip, but very strange is that portforwarding was just done, that is strange by a reset 20sec with power on and power off, wifi password was changed, arla was gone versie 1.0.430.
Router lives its own life
Hope the 2,4ghz is also stable after a long periode
- KernaldFeb 07, 2016Guide
Support asked me to flash 1.0.4.30 and factory reset. I did it yesterday. Ran fine for ~24h, just lost my wifi on 2.4 GHz. I'll flash 1.0.4.28 and factory reset again later today…
- RoadyBoyFeb 07, 2016AspirantI just upgraded from 1.03.60 to 1.06.28, figured I was long over due. Recent email campaign helped motivate me. Should have left well enough alone. Hit this same issue, 5g wireless working fine, 2.4g looks to be online but devices cannot connect saying bad password. Very frustrating. I have a number of Netgear devices and have recommended to a number of friends. I just downgraded to 1.04.30 and so far it is working again. Wasted hours on this. Given the number of messages in this thread I would think and hope Netgear is taking this seriously.
- NiferFeb 08, 2016NETGEAR Employee Retired
Kernald, I am very sorry to hear that the .30 version did not work for you, and I greatly appreciate your patience in rolling back yet again to the .28. Please let us know how that is working for you. I think Tom has been in contact with you about a release candidate firmware, and if you're willing to try one more time, that option seems to be working for tn77. But if you're fed up and just want to stick with something that works, I understand completely. Thanks!
- J_GonzalezFeb 09, 2016Tutor
im
I'm having the same issue. Router is only a couple of months old. I upgraded to 1.0.6.28_1.1.83 when I first set it up (as I normally do on most hardware). I rolled it back to the previous version (i think it was 1.0.5.xxx) same problem.
I haven't yet tried going to 1.0.4.28_1.1.64, but before I do, I would like to try the RC version of the firmware. Just bothers me to go backwards.
Also, I just noticed that on the download page for the R7000, versions 1.05... and 1.06... of the firmware have been removed. The newest firmware available for download is 1.0.4.3
- houseofbugsFeb 09, 2016Tutor
I had this same issue with my R7000. Factory resetting and installing the 1.0.4.30 firmware fixes the issues you are all having. I found this thread when I was having issues a few weeks ago. I just did a write up on my blog:
NetGear R7000 Nighthawk – Wireless and Firmware Issues + Review
- oertjeFeb 09, 2016Aspirant
My router is now with version 10.4.30 stable for more than 48 hours, seems its ok now, but never a update for me lololol
- NiferFeb 09, 2016NETGEAR Employee Retired
Hi Tim - thanks for your feedback. You are correct about the firmware. Through the contributions of people on this thread, we discovered a couple of bugs in the most recent version of firmware. We removed that firmware version from our site.
We encourage any customers who are experiencing issues to download version 1.0.4.30 from our website. If you are not having any issues, there is no need for you to change your firmware.
We have a release candidate version of firmware that we think resolves the bugs, and we hope to release this into production soon.
I apologize for inconveniencing everyone. I am extremely grateful to everyone on this thread who raised this issue.
Thank you!
Nifer
Oertje, thanks for the update on your router with the .30 firmware. I'm sorry about the issues with the update but I am at least thankful that this version is working well for you. Please let me know if you see any new problems. Thanks!
- QfwfqFeb 11, 2016Aspirant
Any idea when I can download the latest corrected firmware version directly via my router? Thanks.
- rpoffenFeb 11, 2016Virtuoso
Qfwfq wrote:Any idea when I can download the latest corrected firmware version directly via my router? Thanks.
I don't think you will be able to do it directly, as there is not yet a new version to correct the 1.0.6.28 problems. You will have downgrade by going to downloadcenter.netgear.com and search for the available downloads by router model. 1.0.4.28 and 1.0.4.30 appear to be the latest stable versions. This will get you a .zip file which you can unpack in Windows simply by double clicking on it, and extracting the .chk file to a known disk location.
Then you login to your router and through the advanced menu, you will be able to change the FW by browsing to the location on your PC you saved the .chk file to.
- NiferFeb 11, 2016NETGEAR Employee Retired
Thanks, rpoffen, for your detailed response!
We hope to have updated firmware in about two weeks that should fix this issue. We have a release candidate that has passed functional testing and is now in QA testing.
As soon as we have a production-ready fix, I'll post a link on this thread to the download center.
I apologize for the problem with the last release and appreciate everyone's patience with us. Thank you for improving our software quality.
- stuckincubeFeb 12, 2016Apprentice
Nifer wrote:Thanks, rpoffen, for your detailed response!
Thanks for the update.
Have the QA tests been updated to catch 2.4GHz issues so this issue never happens again?
- jblackst2800Feb 12, 2016Tutor
rpoffen
Thanks for keeping me posted on the issue I was having with my Netgear R7000 router after updating to the new firmware. I am glad to hear that Netgear is working on it and will have a fix in a couple weeks. I backward upgraded my firmware to V1.0.48 and everything is working fine now. I do understand that comapnies need to keep up to support more people using the latest devices and need to provide firmware to support these. However, I am disappointed that when I called them with my 5 month old (stil under warranty) router that they wanted to charge me additinal money to receive phone support to resolve my issue. I feel that they need to step up when they released a firmware updae that was faulty and provide me the phone support I was asking for. I want to thank everyone on this community forum to help me solve my problem. I am going to hold off on any new firmware releases until Netgear says it has been fixed and I am also hearing the same from everyone on this forum.
Thanks again for your help.
Jim
- HajsterFeb 15, 2016Aspirant
Nifer, thanks for keeping us posted on this fix. I'd recommend one other thing: since so many of us only upgraded our firmware due to the multiple email messages received from Netgear, it would be a good public relations move to send out another email with apology for the mistake. This should be followed by notification of the fix as soon as available.
I've been happy enough with Netgear routers over the years that I'm willing to wait for the fix since I've stabilized using 1.4.30 release. Many others might not be so inclined unless Netgear takes positive steps to acknowledge the frustration they've caused so many people. Customer service is the only way to keep long-term customers when problems arise. Your marketing team should be working on this message just as hard as they worked to push the Arlo architecture out to all of us unsuspecting users.
- NiferFeb 15, 2016NETGEAR Employee Retired
Jblackst2800, I'm happy to hear that the earlier version of firmware is working for you.
Hajster, I think you have a good point. I'm checking with marketing regarding how best to communicate this, as well as evaluating how to prevent this from happening again,
I just received an update from QA a couple of hours ago. This past weekend's testing proceeded uneventfully, with no issues found to date, increasing my hope that we can release updated firmware by the end of this week.
Again, thanks to you all for your patience and assistance.
