jwong84
Sep 10, 2015Aspirant
R7000 2.4ghz not working but 5ghz is fine
Firmware 1.0.4.30 and 1.0.4.28 tried for weeks at a time.
Wireless devices connected to 5ghz band are all working perfectly and have been since i purchased this router at the beginning of June ...
- May 25, 2016
Good news! We now have a production version of firmware that should resolve the 2.4 GHz issue, v1.0.5.64. You may download this firmware from our R7000 page here: http://downloadcenter.netgear.com/en/product/R7000#searchResults
As IrvSp correctly notes, this version of firmware fixes the 2.4 GHz issue and reinstates the new features, such as Kwilt, Smart Connect, and WiFI Transmit Power Control. It does not support Arlo. We hope to have a beta version that supports Arlo in the next two weeks.
We welcome any feedback you provide on this new firmware, and appreciate your patience as we resolved these issues. Thank you all for supporting the R7000 and NETGEAR!
123DaveG
Feb 22, 2016Tutor
I had the 2.4 GH problem downgraded and did the factory reset. Now the router just frequently stops all Wi Fi and needs to power cycle often. it also will not let you log in until this recycle is performed. Called customer support will not do anything unless I pay $139. Considering just buying another router.
rpoffen
Feb 22, 2016Virtuoso
Is the router under warranty? If so, and it turns out that the HW is faulty, then you won't be charged.
- 123DaveGFeb 22, 2016Tutor
No. The router was operating perfectly until I upgraded firmware as suggested in the email.
- KillhippieFeb 24, 2016ProdigyJust because it was working perfectly till you changed firmware does not mean its not hardware. Updating firmware taxes the router, so it could well be a hardware issue that was there or developing and the firmware update has pushed the router and now that issue is showing up. and I would look into this as a hardware issue. I have not personally had any issues with 2.4Ghz on either 1.0.6.28 or 1.0.6.40.
