jwong84
Sep 10, 2015Aspirant
R7000 2.4ghz not working but 5ghz is fine
Firmware 1.0.4.30 and 1.0.4.28 tried for weeks at a time.
Wireless devices connected to 5ghz band are all working perfectly and have been since i purchased this router at the beginning of June ...
- May 25, 2016
Good news! We now have a production version of firmware that should resolve the 2.4 GHz issue, v1.0.5.64. You may download this firmware from our R7000 page here: http://downloadcenter.netgear.com/en/product/R7000#searchResults
As IrvSp correctly notes, this version of firmware fixes the 2.4 GHz issue and reinstates the new features, such as Kwilt, Smart Connect, and WiFI Transmit Power Control. It does not support Arlo. We hope to have a beta version that supports Arlo in the next two weeks.
We welcome any feedback you provide on this new firmware, and appreciate your patience as we resolved these issues. Thank you all for supporting the R7000 and NETGEAR!
123DaveG
Feb 22, 2016Tutor
I did the downgrade and reset, working fine last 10 minutes. fingers crossed. Thanks
123DaveG
Feb 22, 2016Tutor
That worked for almost an hour. I had to do a power cycle to get wi fi working. Guess it's time for router shopping. maybe I will try the Asus? I should have ignored the upgrade firmware email.
- tn77Feb 22, 2016Star
I'm very surprised things aren't working for you still. The hotfix firmware has worked for me for weeks. Apparently 0.28 should work as well. The release version of the firmware is supposed to be this week or next week, based on comments here.
ASUS routers SUCK SUCK SUCK. I bought one and it went bad very shortly after getting started, so I figured it was just a bad router. Bought another one of the same model, same issue. Do not buy their routers! (Although I have three of their laptop/chromebooks with success.)
NETGEAR dragged their feet on this but since the CEO and executive team got involved, they got on creating a fix and they fixed the issue. I think you just need the right version.
- 123DaveGFeb 22, 2016Tutor
I do not see it that way. When I called support they expressed no responsibility and assured me they could fix it, if I paid $139. I will reseach new router options, but I will never consider Netgear.
Yes, their initial responses were horrible. Once I contacted the CEO, everyone in their company understood the magnitude of the issue. I'd consider Netgear in a heartbeat; this router was perfect for 16 months, and it's been fixed since the hotfix. It stinks that their engineering and testing missed this, but ASUS routers (and a few others I've used) aren't in the same league.
