jwong84
Sep 10, 2015Aspirant
R7000 2.4ghz not working but 5ghz is fine
Firmware 1.0.4.30 and 1.0.4.28 tried for weeks at a time.
Wireless devices connected to 5ghz band are all working perfectly and have been since i purchased this router at the beginning of June ...
- May 25, 2016
Good news! We now have a production version of firmware that should resolve the 2.4 GHz issue, v1.0.5.64. You may download this firmware from our R7000 page here: http://downloadcenter.netgear.com/en/product/R7000#searchResults
As IrvSp correctly notes, this version of firmware fixes the 2.4 GHz issue and reinstates the new features, such as Kwilt, Smart Connect, and WiFI Transmit Power Control. It does not support Arlo. We hope to have a beta version that supports Arlo in the next two weeks.
We welcome any feedback you provide on this new firmware, and appreciate your patience as we resolved these issues. Thank you all for supporting the R7000 and NETGEAR!
Killhippie
Feb 25, 2016Prodigy
Did you reset the router after updating? Does your wifes laptop have 5Ghz?
cruxrealm
Feb 25, 2016Aspirant
I did not reset the router. I loaded the firmware and after the reboot, all services worked fine for both 2.4/5 ghz
All wifi devices I tested so far have no issues:
The dual band repeater and dell laptop use both 2.4/5 ghz.
Webcams, game consoles, rpi and hp laptop use only 2.4 ghz.
Apple mac/tv use only 5ghz.
No drops so far for the 24/7 running repeater and webcams.
If you are going to use the beta firmware, just make sure you backup your router config and have a copy of your current working firmware handy in case you want to go downgrade.
