jwong84
Sep 11, 2015Aspirant
R7000 2.4ghz not working but 5ghz is fine
Firmware 1.0.4.30 and 1.0.4.28 tried for weeks at a time.
Wireless devices connected to 5ghz band are all working perfectly and have been since i purchased this router at the beginning of June ...
- May 25, 2016
Good news! We now have a production version of firmware that should resolve the 2.4 GHz issue, v1.0.5.64. You may download this firmware from our R7000 page here: http://downloadcenter.netgear.com/en/product/R7000#searchResults
As IrvSp correctly notes, this version of firmware fixes the 2.4 GHz issue and reinstates the new features, such as Kwilt, Smart Connect, and WiFI Transmit Power Control. It does not support Arlo. We hope to have a beta version that supports Arlo in the next two weeks.
We welcome any feedback you provide on this new firmware, and appreciate your patience as we resolved these issues. Thank you all for supporting the R7000 and NETGEAR!
neonflx2
Feb 25, 2016Tutor
I have done that everytime I flashed the firmware, any other suggestions?
rpoffen
Feb 25, 2016Virtuoso
Do you have your 2.4G band set to auto channel, or do you have a specific one selected?
You can try setting your channel to one that is least used by others in your neighborhood. Try to pick channels 1, 6 or 11 since they don't overlap with each other.
