jwong84
Sep 10, 2015Aspirant
R7000 2.4ghz not working but 5ghz is fine
Firmware 1.0.4.30 and 1.0.4.28 tried for weeks at a time.
Wireless devices connected to 5ghz band are all working perfectly and have been since i purchased this router at the beginning of June ...
- May 25, 2016
Good news! We now have a production version of firmware that should resolve the 2.4 GHz issue, v1.0.5.64. You may download this firmware from our R7000 page here: http://downloadcenter.netgear.com/en/product/R7000#searchResults
As IrvSp correctly notes, this version of firmware fixes the 2.4 GHz issue and reinstates the new features, such as Kwilt, Smart Connect, and WiFI Transmit Power Control. It does not support Arlo. We hope to have a beta version that supports Arlo in the next two weeks.
We welcome any feedback you provide on this new firmware, and appreciate your patience as we resolved these issues. Thank you all for supporting the R7000 and NETGEAR!
neonflx2
Feb 25, 2016Tutor
I have done that everytime I flashed the firmware, any other suggestions?
Killhippie
Feb 25, 2016Prodigy
Did you do reset from the menu or use the reset button on the back. Just wondering if there is a difference I know it should be the same but it's worth mentioning. I always use the reset button on the back and hold for ten seconds. Doing that I have not seen any of these issues at all. I even went back to 1.0.4.30 with no issue which suggests remnants of previous firmwares causing corruption maybe.
