jwong84
Sep 10, 2015Aspirant
R7000 2.4ghz not working but 5ghz is fine
Firmware 1.0.4.30 and 1.0.4.28 tried for weeks at a time.
Wireless devices connected to 5ghz band are all working perfectly and have been since i purchased this router at the beginning of June ...
- May 25, 2016
Good news! We now have a production version of firmware that should resolve the 2.4 GHz issue, v1.0.5.64. You may download this firmware from our R7000 page here: http://downloadcenter.netgear.com/en/product/R7000#searchResults
As IrvSp correctly notes, this version of firmware fixes the 2.4 GHz issue and reinstates the new features, such as Kwilt, Smart Connect, and WiFI Transmit Power Control. It does not support Arlo. We hope to have a beta version that supports Arlo in the next two weeks.
We welcome any feedback you provide on this new firmware, and appreciate your patience as we resolved these issues. Thank you all for supporting the R7000 and NETGEAR!
Killhippie
Feb 25, 2016Prodigy
Don't use a config file after to put back your settings, enter everything by hand. It's a chore but it's the best way to avoid issues. Hope it works.
jblackst2800
Feb 25, 2016Tutor
After I reverted to an earlier firmware V1.0.5.48_1.1.79 I used my backup file to restore my settings. I found that everything worked fine including my 2.4 ghz but all of the port forwarding I had for my cameras and security/home automation system did not work. I had to manually delete them and re-enter and that fixed the problem.
