jwong84
Sep 11, 2015Aspirant
R7000 2.4ghz not working but 5ghz is fine
Firmware 1.0.4.30 and 1.0.4.28 tried for weeks at a time.
Wireless devices connected to 5ghz band are all working perfectly and have been since i purchased this router at the beginning of June ...
- May 25, 2016
Good news! We now have a production version of firmware that should resolve the 2.4 GHz issue, v1.0.5.64. You may download this firmware from our R7000 page here: http://downloadcenter.netgear.com/en/product/R7000#searchResults
As IrvSp correctly notes, this version of firmware fixes the 2.4 GHz issue and reinstates the new features, such as Kwilt, Smart Connect, and WiFI Transmit Power Control. It does not support Arlo. We hope to have a beta version that supports Arlo in the next two weeks.
We welcome any feedback you provide on this new firmware, and appreciate your patience as we resolved these issues. Thank you all for supporting the R7000 and NETGEAR!
Killhippie
Mar 04, 2016Prodigy
That is not the answer, holding netgear accoutable is, also since you did not give any other ways to deal with other issues like using the features in the firmware this conversation is over, you are just a trolling as i see it.
houseofbugs
Mar 04, 2016Tutor
I did actually. Download and try out the AdvancedTomato firmware. I have 0 issues with it, it's been solid for over 2 weeks now with no restarts.
https://advancedtomato.com/downloads/router/r7000
- J_GonzalezMar 04, 2016Tutor
If you install Advanced Tomatoe, can you go back to the Netgear firmware at a later point in time?
