jwong84
Sep 10, 2015Aspirant
R7000 2.4ghz not working but 5ghz is fine
Firmware 1.0.4.30 and 1.0.4.28 tried for weeks at a time.
Wireless devices connected to 5ghz band are all working perfectly and have been since i purchased this router at the beginning of June ...
- May 25, 2016
Good news! We now have a production version of firmware that should resolve the 2.4 GHz issue, v1.0.5.64. You may download this firmware from our R7000 page here: http://downloadcenter.netgear.com/en/product/R7000#searchResults
As IrvSp correctly notes, this version of firmware fixes the 2.4 GHz issue and reinstates the new features, such as Kwilt, Smart Connect, and WiFI Transmit Power Control. It does not support Arlo. We hope to have a beta version that supports Arlo in the next two weeks.
We welcome any feedback you provide on this new firmware, and appreciate your patience as we resolved these issues. Thank you all for supporting the R7000 and NETGEAR!
Nifer
Mar 10, 2016NETGEAR Employee Retired
Hi all, I'm sorry for my delayed response. I've been out of the office with a root canal, so I have not been able to speak directly to the engineer about this, but have only swapped emails with him. Let me share what I understand, recognizing that I may not have all the information.
When we began testing the new beta firmware, we added some new test cases to evaluate the 2.4 GHz in a very noisy environment. In these new tests, we see some wireless disconnects. We think the issue may be with the chipset driver.
Interestingly, most people on this thread have had good success with the beta firmware. Perhaps our noisy testing is more extreme than most customers experience and we're being too cautious in delaying our beta firmware release. But when I read KazzMANIA's post and saw the time investment he made, I'm reluctant to release firmware unless we're certain it's rock solid.
JGonzalez, I'm sorry to hear that the beta firmware didn't work for you, but if you have any config files you could share, we would love to see them.
Again, I'm very sorry for the delay and continue to appreciate the feedback.
J_Gonzalez
Mar 10, 2016Tutor
I do have a config file. Let me know how to send it to you and I will.
Regarding the noise, my client that is having this problem is in a "creative space", which is neo speak for an open floor, a large table with a bunch of people on laptops sitting side by side and across from each other. So perhaps the "noise" comes from a bunch of laptops being spaced a couple of feet apart.
The router in this environment is wall mounted on a backboard, up high, without anything nearby. So it's in a pretty clean location. And it's the only WiFi device in the office.
- NiferMar 11, 2016NETGEAR Employee Retired
Also, thank you for the description of the physical environment. I've shared that with the engineering team. That will help us understand what a noisy environment looks like to a customer and not just in a lab.
- fishboneMar 14, 2016Star
Ok, I was going to sit down and actually downgrade, but...
If I recall correctly the VPN component was upgraded in 1.0.5 to support OpenVPN TAP, which 1.0.4.30 doesn't - so rolling back is not workable as we've already made that switch and some clients only support TAP.
Bottom line - I need the fixed firmware.
