jwong84
Sep 10, 2015Aspirant
R7000 2.4ghz not working but 5ghz is fine
Firmware 1.0.4.30 and 1.0.4.28 tried for weeks at a time.
Wireless devices connected to 5ghz band are all working perfectly and have been since i purchased this router at the beginning of June ...
- May 25, 2016
Good news! We now have a production version of firmware that should resolve the 2.4 GHz issue, v1.0.5.64. You may download this firmware from our R7000 page here: http://downloadcenter.netgear.com/en/product/R7000#searchResults
As IrvSp correctly notes, this version of firmware fixes the 2.4 GHz issue and reinstates the new features, such as Kwilt, Smart Connect, and WiFI Transmit Power Control. It does not support Arlo. We hope to have a beta version that supports Arlo in the next two weeks.
We welcome any feedback you provide on this new firmware, and appreciate your patience as we resolved these issues. Thank you all for supporting the R7000 and NETGEAR!
Leonardo34
Apr 06, 2016Aspirant
I too getting issues... Hope the 2.4ghz gets fixed soon.
And when doing a factory reset, instead of reconfiguring everthing afterwards, is it ok to just use my settings backup to get everthing back right away or its not recommended?
Thx
Thx
- oertjeApr 06, 2016Aspirant
After a broke of my power 230V all my cams have an other port. I have versionV1.0.4.30_1.1.67
Pff I do not know what I must do.
Netgear what is going wrong . It was a expensive router. and I hear nothing from you.
- BlackLabelApr 06, 2016NETGEAR Employee Retired
New beta FW v1.0.5.60 release
https://drive.google.com/file/d/0B9LpH85t3CXeVDhtOHpuSHFJUGM/view?usp=sharing
Please let us know if you are still experiencing the 2.4Ghz not working and/on any 2.4Ghz WiFi stability issues. This beta FW release does not include Arlo integration.
I downloaded the file, I do it tomorrow the update, is there something special I will need to do ? par example hard reset, wifi button on off? or must I do first fabric installation and then the new beta firmware?
- rpoffenApr 06, 2016Virtuoso
oertje wrote:After a broke of my power 230V all my cams have an other port. I have versionV1.0.4.30_1.1.67
Do you mean that the cameras have a different IP address?
If so, then this is normal if all your IP assignments are done via DHCP. What you need to do is either set IP reservations for your cameras (preferred method), or set the cameras up with static IP.
I understand rpoffen, but I did that, all my things I gave a static ip adres in the router, the version I have of firmware is not ok.
Do you think de beta version is ok the one without arlo?
