jwong84
Sep 10, 2015Aspirant
R7000 2.4ghz not working but 5ghz is fine
Firmware 1.0.4.30 and 1.0.4.28 tried for weeks at a time.
Wireless devices connected to 5ghz band are all working perfectly and have been since i purchased this router at the beginning of June ...
- May 25, 2016
Good news! We now have a production version of firmware that should resolve the 2.4 GHz issue, v1.0.5.64. You may download this firmware from our R7000 page here: http://downloadcenter.netgear.com/en/product/R7000#searchResults
As IrvSp correctly notes, this version of firmware fixes the 2.4 GHz issue and reinstates the new features, such as Kwilt, Smart Connect, and WiFI Transmit Power Control. It does not support Arlo. We hope to have a beta version that supports Arlo in the next two weeks.
We welcome any feedback you provide on this new firmware, and appreciate your patience as we resolved these issues. Thank you all for supporting the R7000 and NETGEAR!
Jdr01960
Apr 11, 2016Aspirant
The workaround that works for me is to enable guest mode on 2.4. When I do this, devices connect to normal 2.4. With 2.4 guest off, devices only connect to normal 5 ghz.
Just updated to the latest official firmware tonight and turned guest mode off thinking the issue would be resolved....nope. needed to turn 2.4 guest back on. I have access control off and do not broadcast the guest 2.4. Both normal 2.4 and 5 have same ssid and pass.
