jwong84
Sep 10, 2015Aspirant
R7000 2.4ghz not working but 5ghz is fine
Firmware 1.0.4.30 and 1.0.4.28 tried for weeks at a time.
Wireless devices connected to 5ghz band are all working perfectly and have been since i purchased this router at the beginning of June ...
- May 25, 2016
Good news! We now have a production version of firmware that should resolve the 2.4 GHz issue, v1.0.5.64. You may download this firmware from our R7000 page here: http://downloadcenter.netgear.com/en/product/R7000#searchResults
As IrvSp correctly notes, this version of firmware fixes the 2.4 GHz issue and reinstates the new features, such as Kwilt, Smart Connect, and WiFI Transmit Power Control. It does not support Arlo. We hope to have a beta version that supports Arlo in the next two weeks.
We welcome any feedback you provide on this new firmware, and appreciate your patience as we resolved these issues. Thank you all for supporting the R7000 and NETGEAR!
tn77
Apr 11, 2016Star
We shouldn't be testing for NETGEAR anyway. Maybe the CEO needs another letter?
- oertjeApr 11, 2016Aspirant
You are right, Netgear must give a good version, we are waiting too long, it is crazy and world up side down!
- NiferApr 14, 2016NETGEAR Employee Retired
Oertje, have you tried the new beta firmware? Is that working for you? Thanks! Nifer
- oertjeApr 17, 2016Aspirant
Ik heb nu version 1.05.60.1.1.86 and I did no reboot or power off or anything else and it was quick and all my settings are in the router after upgrading.
It seems good...... Now the time brings the stability......
Thanks for so far
