jwong84
Sep 10, 2015Aspirant
R7000 2.4ghz not working but 5ghz is fine
Firmware 1.0.4.30 and 1.0.4.28 tried for weeks at a time.
Wireless devices connected to 5ghz band are all working perfectly and have been since i purchased this router at the beginning of June ...
- May 25, 2016
Good news! We now have a production version of firmware that should resolve the 2.4 GHz issue, v1.0.5.64. You may download this firmware from our R7000 page here: http://downloadcenter.netgear.com/en/product/R7000#searchResults
As IrvSp correctly notes, this version of firmware fixes the 2.4 GHz issue and reinstates the new features, such as Kwilt, Smart Connect, and WiFI Transmit Power Control. It does not support Arlo. We hope to have a beta version that supports Arlo in the next two weeks.
We welcome any feedback you provide on this new firmware, and appreciate your patience as we resolved these issues. Thank you all for supporting the R7000 and NETGEAR!
jguerdat
May 25, 2016Guru
I see that v1.0.5.64 is released on the downloads page. Does this one support Arlo, also?
- IrvSpMay 25, 2016Master
No.
- NiferMay 25, 2016NETGEAR Employee Retired
- Daydream_llMay 27, 2016Star
Hi, installed new firmware yesterday and so far only issue is the reach of 5GHz band. I live in a fairly small apartment and with older firmwarfe signal reached all corners, now it does not. Earlier it reached the 12 m to balcony and now i have to be inside.
Has anything changed in the strength of the signal?
I can no longer access router from remote site either and genie for iphone, or mac. Even the webbrowser works very slow when logging on to the router from home, feel like the router has slow respons to genie software (it is upgraded to latest versions too)
Best regards
Lennart
