jwong84
Sep 10, 2015Aspirant
R7000 2.4ghz not working but 5ghz is fine
Firmware 1.0.4.30 and 1.0.4.28 tried for weeks at a time.
Wireless devices connected to 5ghz band are all working perfectly and have been since i purchased this router at the beginning of June ...
- May 25, 2016
Good news! We now have a production version of firmware that should resolve the 2.4 GHz issue, v1.0.5.64. You may download this firmware from our R7000 page here: http://downloadcenter.netgear.com/en/product/R7000#searchResults
As IrvSp correctly notes, this version of firmware fixes the 2.4 GHz issue and reinstates the new features, such as Kwilt, Smart Connect, and WiFI Transmit Power Control. It does not support Arlo. We hope to have a beta version that supports Arlo in the next two weeks.
We welcome any feedback you provide on this new firmware, and appreciate your patience as we resolved these issues. Thank you all for supporting the R7000 and NETGEAR!
TheEther
Jun 01, 2016Guru
It's less common but compatibility issues can also happen when moving forward. It happened when Netgear made some changes to port forwarding in the release after 1.0.4.30.
Netgear's configuration file format was not designed with version compatibility in mind. If they adopted a structured data format, like Google Protocol Buffers or even XML, then these issues wouldn't occur. Obviously, that will require engineering development to make the switch. It's not clear that that is a cost Netgear is willing to incur.
