routerkm
Apr 10, 2017Aspirant
R7000 2.4ghz Wifi crashes internet
I have a ADSL2+ modem that connects (via a switch) to my R7000 router. Even after a hard reset, putting it in Access Point Mode and disabling QOS, as soon as the 2.4GhZ wifi is turned on, the entire...
- Apr 10, 2017
Hi
Thank you for your reply.
I think I may have fixed it. Whilst I beleived nothing was connecting to the wireless connection as everything seemed either off or disconnected, I changed the wifi network password to force disconnect everything from connecting. Then once I turned the wifi on the internet did not come to a hault on any device.
The r7000 still acts as a AP as the modem does have a wireless.
Thanks for your response. Hope this may help someone solve their issue.
thanks
mondenath
Apr 10, 2017Prodigy
Can you try setting the r7000 as router instead of AP. As the Modem doesnt have a wifi. You can set it as router. The AP is only suited well if you are extending the exisiting wifi to another room when connected wired. As AP does lose the most usefull feature even one decided to not use.
routerkm
Hi
thanks
