Thetrusammael
Jan 02, 2019Guide
R7000 5g keeps losing internet. 2.4 unaffected.
I've been using this router for quite some time and this just started happening. Clients on the 5g will suddenly lose internet but remain connected. If I change the channel on 5g manually, it will be...
- Jan 10, 2019So, rolling back to 1.0.9.42 seems to have solved my issue, but I'm not so confident in their firmware releases now.
Here's to hoping they don't break anything else. đ
Thetrusammael
Jan 03, 2019Guide
V1.0.9.60
IrvSp
Jan 03, 2019Master
Wifi is quite common to have problems with this f/w version. Backup one version, V1.0.9.42, reset router, reenter settings (you could try it without doing that but later you might discover other problems) and you should be fine. NG basically has partially pulled that release.
- ThetrusammaelJan 03, 2019Guide
Ok, I rolled back to 1.0.9.42
.60 is still being advertised as the most recent firmware, FYI.
I will update this when I see if the stability issues have been resolved.
- IrvSpJan 03, 2019Master
It should be better with the older f/w. Note I said 'partially'. Although it does still show on the Support site, it was pulled from the Auto-Update server (I've seen posts to that) so routers aren't automatically updated to it. If I am wrong (my R7000 is not in use) I'm sorry for the misinformation on that.
