Mister-X
Jul 19, 2019Guide
R7000 5G
For those of you having trouble with 5G Signals, within my settings I have Enable 20/40 MHz Coexistenceunchecked(meaning Off), QoS is unchecked(Off) but WMM should be checked(meaning On) because WMM ...
- Jul 19, 2019
Go to https://www.netgear.com/support/product/r7000.aspx#download
and click at the plus sign on lower left that says "View Previous Versions"
Mister-X
Jul 19, 2019Guide
Try this link, it's from Netgear itself: https://kb.netgear.com/000060566/R7000-Firmware-Version-1-0-9-64
After becoming aware of a New Firmware Upgrade being available, I go to Netgear.com>Support>>Type in R7000 in the Search>>Downloads>>> then find the Current Version of the Firmware there and download it into my Computer in order to save a copy.
That way if there are any issues with the New Firmware, which has been rare for me, you'll always have a copy of a previous version that worked for you until the bugs are worked out of the new one as is the case right now with the V1.0.9.88_10.2.88 Firmware. This is the first real issue I've had with a Firmware Upgrade.
Hope that helps and Good Luck!!
Wladue613
Jul 19, 2019Guide
Great advice. Thank you.
