ov10mech
Mar 30, 2019Star
R7000 5ghz not stable
Running latest firmware V1.0.9.64_10.2.64 - Multiple devices connected to the 5GHZ side are very unstable. If you do a constant ping to the router you can see the dropped packets as shown in atta...
- Mar 30, 2019
Agreed, many people are having issues with the current firmware. You can downgrade to earlier firmwares though. Have you tried this?
TheEther wrote a great response to someone on how to do so. its here:
Mar 30, 2019Guru - Experienced User
ov10mech
Mar 30, 2019Star
I will give that a try. What version is considered stable? I only use simple port forwarding and WIFI in the house.
- plemansMar 30, 2019Guru - Experienced User
Nothings ever really perfectly stable or manufacturers wouldn't update firmware. With that said, I've heard good things about the .42 firmware. If you're a more advanced user you can always look into dd-wrt but that'd be a different forum :)
- ov10mechMar 31, 2019Star
Downgraded last night to V1.0.9.42_10.2.44 - Didnt do any of the factory reset stuff. It's a world of difference. Not a single ping lost in hours and noticed the latencey is not all over the place like it was. The internet seems so much snappier like I am hard wired. Lesson leared : Dont upgrade just to upgrade.
