evilhomer1
Nov 17, 2017Tutor
R7000 5Ghz WiFi speeds
Hi all, I have an AC1900 router connected to an ARRIS SURFboard SB6190. I'm subscribed to Xfinity Internet on the Blast plan and can verify that I get 200+ Mbps when wired directly into the modem...
- Nov 21, 2017
I finally figured out the solution.
The QOS database was out-of-date.
Even though I don't have QOS on, apparently this can still impact the speeds because I'm back to running normally now.
To manually update the database, I checked the Enable QOS checkbox and then pressed the Update Now button.
Hopefully this will help others.
IrvSp
Nov 18, 2017Master
You recently updated the firmware but did you reset and re-enter your settings or re-load old saved settings?
Is QoS enabled? If so is the speed setting correct? If you disable it, does that correct the problem? WMM must be enabled though.
- evilhomer1Nov 18, 2017Tutor
Hi, I factory reset all settings before upgrading firmware.
Once upgraded, the only settings I changed were my WiFi network names.
QoS is turned off but WMM is turned on.
- Pirat28Nov 21, 2017Aspirant
I have the same problem. It started with the firmware version V1.0.9.10 (I like to call this on "The Disney circle update") and include also the firmware version V1.0.9.12.
So I switched back to version V1.0.9.6 where the 5Ghz WiFi speed is ok.
I'm in contact with the Netgear support, but at the moment they found no real solution for my problem.
- evilhomer1Nov 21, 2017Tutor
