Troyer
Jan 10, 2019Aspirant
R7000 AC 1900 Wifi Router
Hi - I had to reset the router. What is the IP address where I need to change the password? Thank you!
- Jan 11, 2019
There is support material, including a manual, for the R7000 somewhere at the end of this link:
>>>> R7000 | Product | Support | NETGEAR <<<<
Troyer
Oh and I forgot to mention that a user guide was not in the box unfortunately. It seems most electronics don't come with user guides anymore. I will have to search for it on line I guess.
antinode
Jan 10, 2019Guru
> [...] I will have to search for it on line I guess.
Not much searching is required. Visit http://netgear.com/support ,
put in your model number, and look for Documentation. Get the User
Manual (and anything else which looks interesting). Read.
> [...] I called Netgear and they gave me routerlogin.net. But it says
> it's not a secure location and to not enter sensitive info like
> passwords. [...]
"it", in this case is your web browser, which may be complaining
because it's worried about your sending some user credentials over an
unencrypted/insecure link ("http://" instead of "https://"). The easy
thing to do is ignore the warning, and proceed. Presumably, you're
talking to your own gizmo on your own LAN. If someone can overlisten to
that traffic, then you're already in big trouble.
