Troyer
Jan 10, 2019Aspirant
R7000 AC 1900 Wifi Router
Hi - I had to reset the router. What is the IP address where I need to change the password? Thank you!
- Jan 11, 2019
There is support material, including a manual, for the R7000 somewhere at the end of this link:
>>>> R7000 | Product | Support | NETGEAR <<<<
Troyer
Oh and I forgot to mention that a user guide was not in the box unfortunately. It seems most electronics don't come with user guides anymore. I will have to search for it on line I guess.
michaelkenward
Jan 11, 2019Guru - Experienced User
- TroyerJan 11, 2019Aspirant
Thank you!
