JMatsCA
Feb 18, 2019Initiate
R7000 AC1900 5Ghz intermittent connection failures
Purchased R7000/AC1900 in April 2018 so it's been about 10 months (currently mid-Feb 2019).
About 3 months ago (mid-Nov 2018), I started noticing that the 5GHz connection occasionally drops. The S...
- Feb 19, 2019
Your troubles started just as they should, namely once you updated to .60. Revert to FW .42, and they will go away. Both .60 and .64 are bad.
