longs91peak's avatar
longs91peak
R7000 AC1900 Allow guests to see each other and access my local network
I expect the answer is simple, but I don't know it and can't find one via searches   When checking the 2.4 Guest Wireless 'Allow guests to see each other and access my local network', which of the ...
  • NwSkier's avatar
    Apr 17, 2020
    Local network refers to your LAN which includes all enabled interfaces OTHER than guest networks. The guest network allows access to the WAN but is segmented from your LAN, much like Comcast uses their Xfinity wifi hotspots broadcast from customer's access points.
    When you check the option you are referring to, this basically bridges the two network segments and allows your guest access to your LAN like any other interface. Great for testing or allowing temp access, but essentially removing the whole reason you'd want then to use the guest network in the first place. I mean unless you really don't want then to know your primary interface passwords.
