GlenReid
Feb 01, 2021Guide
R7000 ac1900 Can't login
I'm not able to access web pages. When I try to login to the router I get a terms and conditions screen that tells me I must agree to the terms or return my router, with a 2017 last updated. I can pi...
- Feb 01, 2021
Really struggling with what I do if I do a reset to factor defaults (which I haven't done yet) and this same message pops up. And of course I could get a new router and install it and maybe the same message pops. Is Netgear setting the message or is a piece of malware in my computer setting. Hmmm...
I've got an old xp machine sitting in the corner that hasn't been on line lately. Maybe I should hook the router up to it and see what happens. :)
I don't know. I'm going to let this cook overnight or so and see what seems to make sense tomorrow.
Thanks for your efforts.
Feb 01, 2021Guru - Experienced User
I don't have a r7000 to test it on.
But if you've factory reset it, there shouldn't be anything on it.
Plus you could always disconnect it from the modem and set it up
GlenReid
Feb 01, 2021Guide
