Sneaks37
Feb 21, 2024Aspirant
R7000 AC1900 Channel 0 on 5Ghz
Hello, I'm having problems with my setting up my 5Ghz Wifi. No matter to what channel i change it's shows channel 0 at the home screen. If i change to up to 1300Mbps the channel changes to some Chin...
Feb 21, 2024Guru - Experienced User
What browser are you using? Try MS Edge, Firefox or Opera.
Be sure to clear out all browser caches before entering the routers web page.
Happens with Smart Connect enabled or disabled?
What region are you located?
Sneaks37
Hmm, haven't tried a factory reset. Will try as soon i'll get a moment. I'll post later the results.
I'm using Opera by default, but using a clean MS Edge didn't helped either.
Happens on both Smart connect disabled and enabled.
I'm located in Europe.
- FURRYe38Feb 22, 2024Guru - Experienced User
đ
- Sneaks37Feb 22, 2024Aspirant
I did a factory reset and unfortunately this time it shows some gibberish instead of Chinese symbols in channel number. This is very strange.
- microchip8Feb 22, 2024MasterI think it's time for a new router. The R7000 is over a dacade old.
