3arc
Oct 12, 2019Aspirant
R7000 ac1900 has amber light after a firmware update on the netgear nighthawk app
I need help with the tftp method when you need to count 10 flashing led before entering.
- Oct 12, 2019
How to upload firmware to a NETGEAR router using Windows TFTP | Answer | NETGEAR Support
And go out into Google/Bing and find a video that takes you though the process.
By the way, you will gain nothing by starting multiple discussions of the same problem:
Re: R7000 AC1900 Bling power light after failed ... - Page 3 - NETGEAR Communities
Re: R7000 power Led stays orange when turned on af... - NETGEAR Communities
michaelkenward
Oct 12, 2019Guru - Experienced User
3arc
Oct 13, 2019Aspirant
Michael what would be the safest easy way to update my router to the newest firmware with windows HP i am no longer going to do it on the nighthawk app or any way not that's not a wired connection btw sorry for the trouble
