jonjon79's avatar
jonjon79
R7000 AC1900 Layer 2 only?
hi. I have a R7000 AC1900 Nighthawk wireless router that I would like to use as just a Layer 2 switch, no wireless, no routing, just Layer 2 to downstream devices connecting them upstream to my ISP g...
  • FURRYe38's avatar
    Well give router mode a try, disable DCHP and wifi on the router and connect it using one of it's LAN ports.
