Avalanche2121
Jan 31, 2019Tutor
R7000 AC1900 Restarts when wifi downloads exceed 1mb per second
My r7000 has been restarting itself when downloading seems to exceed 1mb/s I know this is the problem because I've throttled the download speeds to below a mb and it works ok. Can this router not h...
- Mar 14, 2019It's the firmware, just loaded ddwrt, works fine now.
DarrenM
Jan 31, 2019Sr. NETGEAR Moderator
We released a new firmware see if that changes anything.
https://kb.netgear.com/000060566/R7000-Firmware-Version-1-0-9-64-All-Regions-except-China
DarrenM
- Avalanche2121Jan 31, 2019TutorNope, just updated and tested, still reboots....
- twitchyJan 31, 2019AspirantWell. No such luck.
Seems like the device still wants to continually reboot after 2-10 minutes of playing games and streaming.- twitchyFeb 01, 2019Aspirant
I resolved this issue with a downgrade to 1.09.34 last night.
Everything is working as expected at this point (including my Circle device).
I will attempt an upgrade to 1.09.42 tonight, and see how that works out, but I recommend the downgrade at this point for you as well, to see if that helps at all.
- JWS9518Feb 06, 2019Luminary
DarrenM
Darren
Your new firmware is garbage..with constant random reboots and connection issues. .42 is the last firmware that worked well.
