Avalanche2121
Jan 31, 2019Tutor
R7000 AC1900 Restarts when wifi downloads exceed 1mb per second
My r7000 has been restarting itself when downloading seems to exceed 1mb/s I know this is the problem because I've throttled the download speeds to below a mb and it works ok. Can this router not h...
- Mar 14, 2019It's the firmware, just loaded ddwrt, works fine now.
Avalanche2121
Jan 31, 2019Tutor
Nope, just updated and tested, still reboots....
twitchy
Jan 31, 2019Aspirant
Well. No such luck.
Seems like the device still wants to continually reboot after 2-10 minutes of playing games and streaming.
- twitchyFeb 01, 2019Aspirant
I resolved this issue with a downgrade to 1.09.34 last night.
Everything is working as expected at this point (including my Circle device).
I will attempt an upgrade to 1.09.42 tonight, and see how that works out, but I recommend the downgrade at this point for you as well, to see if that helps at all.
- Avalanche2121Feb 04, 2019TutorNo deal, still junk lol
- twitchyFeb 04, 2019AspirantSame boat it seems. 1.09.34 worked for a few days. And just had repeat disconnects... This is not fun :(
