Avalanche2121
Jan 31, 2019Tutor
R7000 AC1900 Restarts when wifi downloads exceed 1mb per second
My r7000 has been restarting itself when downloading seems to exceed 1mb/s I know this is the problem because I've throttled the download speeds to below a mb and it works ok. Can this router not h...
- Mar 14, 2019It's the firmware, just loaded ddwrt, works fine now.
twitchy
Mar 20, 2019Aspirant
Have you had any issues since switching to ddwrt?
Avalanche2121
Mar 20, 2019Tutor
I have had some setting and config issues, as i am using this router as a bridge now. However, the original problem of restarts due to wifi downloads has been resolved. I have downloaded multiple items at high download rates and the router has stayed on and not disconnected/restarted.
- shadowsportsMar 21, 2019Hero
Can't speak for any of thre FW revs since 1.0.9.42. Stability has not been an issue in my 5 years of R7000 ownership.
The router has never restarted under any circumstances regardless of the load put on it's interfaces (wired or wireless). While this could be an issue with FW above .42 (I have no experience with them). The hardware is not inheriently faulty, anyone having stabilty issues, unexpected restarts, etc, should look at their FW and how it was loaded.
The most common cause of instability and restarts (at least with earlier revisions) is corrupt FW loaded using auto-check and update, automatic update or using Genie via a wireless connection.
