blhsfc91
Feb 26, 2021Tutor
R7000 AC1900 Router
I’m trying to eliminate dead spots and weak spots in my wifi signal at the house. I have an ASUS ROG router as my main router. I was able to successful hookup the one it replaced as a wifi repeater...
- Mar 01, 2021
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
Feb 27, 2021Guru - Experienced User
blhsfc91
Mar 01, 2021Tutor
i've tried that but i can't get to the admin pages to go through those steps. it says to use an ethernet connection (Note: Use a wired Ethernet connection during setup to avoid interfering with your wireless connection.). but connection back to what? i tried an ethernet connection to my existing router and i've connected it to my laptop, doesn't work. if i connect it to my modem, then i can't wirelessly connect to my main router.
- Launch an Internet browser from a computer or wireless device that is connected to your Nighthawk router’s wireless network. - since the netgear router isn't coming on line, it is not showing a wireless network.
- Visit http://www.routerlogin.net. If http://www.routerlogin.net does not work, try the following:
- http://www.routerlogin.com
- http://192.168.1.1
- http://192.168.0.1
- http://10.0.0.1
- NONE OF THESE WORK IN A BROWSER
- plemansMar 01, 2021Guru - Experienced User
- blhsfc91Mar 01, 2021Tutor
TADA. i was able to get the nmrpflash process to work and push the firmware upgrade. my router is now operating correctly. I'm able to see the netgear wifi network and the lights are no longer cycling.
thank you for all your help and useful links to get this resolved.
Glad you got it working!
