m130carbine
Nov 24, 2020Tutor
R7000 AC1900 Slow Download speed wired
Hello, Hoping to get some help on my situation from the smart folks. I have Spectrum Internet with a 100 Mbps connection. 1.The speed test wired to my pc from Spectrum modem shows download of 100+...
Nov 24, 2020Guru - Experienced User
Which version of firmware are you on?
What modem/gateway is it connected to?
After the reset, did you do a clean install or did you use a backup?
m130carbine
Nov 24, 2020Tutor
Firmware Version 1.0.11.110
Not sure of the modem from Spectrum but it does work well when connected to the Spectrum modem by itself.
After the reset I just allowed it to come back up from what it came up with with no backup. I just set a password on it for now and left it at that. Same speeds. I can try to find out the modem from Spectrum this afternoon. Just looking online at them it looks like the Orbi RBK44 but I am not sure. I do know that the download speeds are great when connected to the modem itself from Spectrum.
Thanks for the reply a bunch.
- plemansNov 24, 2020Guru - Experienced User
yes, when you find out the modem/gateway, post it back on here.
- m130carbineNov 24, 2020Tutor
The modem is a
MotorolaModelE31U2V1- plemansNov 24, 2020Guru - Experienced User
Try installing version 1.0.9.42 of the firmware for the R7000. Then do a factory reset and clean install (not from backup).
