HaHaJe
Oct 31, 2022Aspirant
R7000 AC1900 smart wifi router update firmware
My 8years old R7000 router shows firmware = V1.0.11.106 When I ask to check for firmware-updates, the answer is: you have the latest firmware version. And when I search in Netgear Support for the l...
Oct 31, 2022Guru - Experienced User
Yes. Use a wired PC and web browser. MS Edge or FireFox.
HaHaJe
Thanks for the advice.
I discovered the difference between firmware versions because the power on/off button was red, and sometimes
white, but on and off white. I read that this was a sign of bad internet.
The router is 8 years working now. Should I replace the AC7000 by a new router ?
- FURRYe38Oct 31, 2022Guru - Experienced User
I would ensure the ISP services and modem are in good working condition first...
- HaHaJeOct 31, 2022Aspirant
the router is connected to ARRIS TG2492LG-85 modem.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.Try option #2 first.
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
- michaelkenwardOct 31, 2022Guru - Experienced User
I don't know where you read that. The power LED will change as the router boots up. If it doesn't settle down to a solid white LED, you may have broken firmware. But that isn't a transient thing. After the boot sequence, the firmware, and router, is ether dead or alive.
The router is 8 years working now. Should I replace the AC7000 by a new router ?If it still works, and you don't have any real problems, that's your call. The R7000 was never the most advanced router in the shelves, but it has been a reliable workhorse for many people. And as you have found Netgear continues to provide security updates.
You could look around to see what features you could get with a new router.
