HaHaJe
Oct 31, 2022Aspirant
R7000 AC1900 smart wifi router update firmware
My 8years old R7000 router shows firmware = V1.0.11.106 When I ask to check for firmware-updates, the answer is: you have the latest firmware version. And when I search in Netgear Support for the l...
HaHaJe
the modem is bridged
Oct 31, 2022Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
- HaHaJeNov 01, 2022Aspirant
I might have a problem with the update off the firmware: my laptop can not connect to the internet wired.
I will control all the suggestions you told me (First the LAN cable), and be back home on friday.
