HaHaJe
Oct 31, 2022Aspirant
R7000 AC1900 smart wifi router update firmware
My 8years old R7000 router shows firmware = V1.0.11.106 When I ask to check for firmware-updates, the answer is: you have the latest firmware version. And when I search in Netgear Support for the l...
HaHaJe
You are right ! I am just asking can I do the update to the right firmware without risc ?
Because the freaky LED suggest that there is a firmwarebreak.
I did stop the modem and the router, and restarted both of them. And the LED was white for a few moments
and is now red again. And I am able to mail with you and surf on the internet.
michaelkenward
Oct 31, 2022Guru - Experienced User
HaHaJe wrote:
And the LED was white for a few moments and is now red again. And I am able to mail with you and surf on the internet.
Which LED power or Internet?
Sounds like the router is working but did you do it in the required order?
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
- HaHaJeNov 01, 2022Aspirant
I have a problem with the power-LED
I switchted all other LEDS, when I change that the router is like a white lightshow.
And the sequense in restart: I will do that next time I restart.
I am away for a couple of days, be back on friday.
