WelshJohn
Sep 11, 2019Aspirant
R7000 AC1900 totally "bricked" after attempt to update to latest firmware
Latest Firmware upgrade ended up totally "Bricking" my router, Followed all hints to get back up and running first thing that appeared to be screwed up was the Hard Reset after power on did not seem...
- Sep 11, 2019
> [...] the TFTP proceedure which is documented in many threads, [...]
I'll just go look at "many threads", then, all of which said exactly
the same thing(s), to figure out what you did? Guess again.> [...] with a fixed IP set up [...]
Which "a fixed IP"?
> [...] using the command lin prompts [...]
Which commands? As usual, showing actual actions (commands) with
their actual results (error messages, LED indicators, ...) can be more
helpful than vague descriptions or interpretations. Copy+paste is your
friend.> [...] i got amsg indicating [...]
What was the actual message? Again, copy+paste is your friend.
antinode
Sep 11, 2019Guru
> Latest Firmware upgrade [...]
Performed how, exactly?
> [...] ended up totally "Bricking" my router,
Not a useful description. What does the router do? LED indicators?
> Followed all hints [...]
Not a useful description of anything. What did you do? What
happened when you did it?
> [...] Hard Reset after power on did not seem to follow suggested
> behaviour.
Which "suggested behaviour"? And even if we knew exactly what didn't
happen, more useful would be some description of what did happen.
> I attmpted the TFTP procedure [...]
Which "the TFTP procedure"? "attmpted the TFTP procedure" is not a
useful description of a procedure with multiple steps and multiple
user-supplied data, hence multiple opportunities for error.
- WelshJohnSep 11, 2019Aspirant
Firstly, thank you pointing out the relative uslessness of my post, I will try and do better. see comments below
antinode wrote:> Latest Firmware upgrade [...]
..... Router never restarted Power Light was flashing Amber and the Lan ports that had cablesconnected were flashing intermittently.
Attempts to power OFF and reset using the reset button failed
happened when you did it?Googled the fault and there were several threads that explained that the unit had to be had to be rest and that using the TFTP process as decscribed in a number of threads woudl fix the issue.. this was done immedietly the fault (Firmware upgrade failed)
> behaviour.Which "suggested behaviour"? And even if we knew exactly what didn't
happen, more useful would be some description of what did happen.Following guidance from other threads, the Unit was powered off, then with the Rest Button pressed, the unit was suppossed to show the Power button perminenmtly on then starting to flash, after flashing 7 times or more i could release teh reset button. at which time the power button would light steadily. none of this happened.
user-supplied data, hence multiple opportunities for error.the TFTP proceedure which is documented in many threads, to down l,oad the Router firmware, unpackit, then using the command lin prompts start a TFTP link using a Lan connection to the router with a fixed IP set up, which is supposed to upload the selected firmware into the router, this did not happen as i got amsg indicating 0 bytes transferred.
https://community.netgear.com/t5/x/x/m-p/1622096#M102004
- antinodeSep 11, 2019Guru
Which "a fixed IP"?
I was genuinly hopeing that i could get a level of help from this forum, but the confontational style of antinode Sensei is not contructive or a pleasant expiernce,
So i withdraw from this thread and ask the moderatros to close it please.
My next Router will NOT be a Netgear and possibly for the wrong reasons.
