WelshJohn's avatar
WelshJohn
R7000 AC1900 totally "bricked" after attempt to update to latest firmware
Latest Firmware upgrade ended up totally "Bricking" my router, Followed all hints to get back up and running first thing that appeared to be screwed up was the Hard Reset after power on did not seem...
  • antinode's avatar
    antinode
    Sep 11, 2019
    > [...] the TFTP proceedure which is documented in many threads, [...]
       I'll just go look at "many threads", then, all of which said exactly
    the same thing(s), to figure out what you did?  Guess again.
    > [...] with a fixed IP set up [...]
       Which "a fixed IP"?
    > [...] using the command lin prompts [...]
       Which commands?  As usual, showing actual actions (commands) with
    their actual results (error messages, LED indicators, ...) can be more
    helpful than vague descriptions or interpretations. Copy+paste is your
    friend.
    > [...] i got amsg indicating [...]
       What was the actual message?  Again, copy+paste is your friend.
