markinms's avatar
markinms
R7000 Access Questions
I'm new to this and can't find an answer for my question.
Can my laptops using wifi access a cabled printer?  Or...
Can my desktops using cabled access, access a printer setup on the wifi network?
Using the R7000 printer sharing option is not an option.
Thanks for any feedback!
Mark
  • R7000 has wireless isolation, but only for the guest network.
  • Babylon5's avatar
    Babylon5
    NETGEAR Employee Retired
    If the printer is a network printer with WiFi / Ethernet support then yes to both your questions. The only router related parameter that I can think of which may cause issues is ‘Wireless Isolation’ (default is disabled), so check it’s disabled (assuming the R7000 has that feature, I can’t check right now).
    • TheEther's avatar
      TheEther
      Guru
      • markinms's avatar
        markinms
        Thanks for the quick responses.
        The printer is a wifi/ethernet network printer but will not allow both at the same time.
        Right now all devices/computers are wifi.  Desktop performance  is compromised by doing this; cable internet is 100Mbps, I get half this with wifi.
        Mark
