johnwmcc
Mar 09, 2022Aspirant
R7000 address reservation not working as expected for attached devices
Model R7000 NightHawk router Firmware V1.0.11.128_10.2.112 Mac Monterey 12.2.1, home Ethernet and WiFi network, ISP Virgin Media cable connection, using Hub 3 as cable modem only. DHCP is enabl...
GregGreg
Mar 14, 2022Star
You write about using addresses from the IP private network 192.168.0.255/24
As far as I know, this defaults IP network used by Virgin HUB 3
Router Netger R7000 use IP private network 192.168.1.255/24 (default).
It looks like you have changed the IP address on the R7000 router (from 192.168.1.255/24 to 192.168.0.255/24)
You cannot have the same networks on both sides of the R7000 (WAN and LAN)(Routing will not work in this case)
- johnwmccMar 14, 2022Aspirant
The Virgin Media Hub 3.0 is configured as a modem only, with IP address 192.168.100.1.
From installation I have configured the R7000 with the IP address 192.168.0.1, as a DHCP server serving addresses in the range 192.168.0.2-254.
There are no other active DHCP servers on the network, although there are three other devices that could act that way. But they are all configured as access points, with DHCP service turned off.
- FURRYe38Mar 14, 2022Guru - Experienced User
What happens if you set the default DHCP IP address range to 192.168.1.100 to .200?
You might want to try the new FW as well:
