tomign
Jan 20, 2018Aspirant
R7000 after firmware upgrade doesn't allow port forwaring to Synology DSM
Hello, for a long period of time I had Synology DSM 115 connected to router. There were configuered a few ports via UPnP to access DSM from external source (3042 for access and some other like 8001,...
antinode
Jan 20, 2018Guru
> [...] have upgraded firmware to the newest one, tried to set up port
> forwarding manually and still it doesn't work.
An actual firmware version number would be more helpful than your
opinion of what's "the newest" (today).
Copy+paste your port-forwarding rules.
"doesn't work" is not a useful problem description. It does not say
what you did. It does not say what happened when you did it. As usual,
showing actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
> [...] the IP of my DSM in local network on 192.168.1.3.
You did something to ensure that your "my DSM" always has that IP
address? (What?)
Can you access your "my DSM" from within your LAN at the router's
WAN/Internet IP address? (That should be "mystaticip". Is it?)
- tomignJan 20, 2018Aspirant
Hello,
at first I had upgraded to 1.0.9.18. Then to 1.0.9.20_1.2.28.
My port forwarding rules:
1 3042 3042 3042 192.168.1.3 2 80 80 80 192.168.1.3 3 8001 8001 8001 192.168.1.3 4 6281 6281 6281 192.168.1.3 5 5006 5006 5006 192.168.1.3 After it stopped working, I mean I couldn't access to DSM from external network, I have restarted the router and used DSM to auto configure via UPnP port forwarding. It didn't help, so I have turned of UPnP and added port forwarding manually, as listed above. It didn't help.
I turned on Remote management on port 8443. I have checked it from outside the network (via LTE connection) and it works OK.
I have upgraded to 1.0.9.18 and repeated above procedure. It didn't help.
I have upgraded to 1.0.9.20_1.2.28 and repeated above procedure. It didn't help.
There are no errors shown in logs or in router admin page. LED indicators shows everything is OK.
I have setup 192.168.1.3 to my DSM in both DSM settings and in router admin page, assigned this IP to DSM MAC.
WAN/Internet IP address? (That should be "mystaticip". Is it?)Yes, I can access DMS via https://mystaticip:3042 from within my LAN.
