tomign
Jan 20, 2018Aspirant
R7000 after firmware upgrade doesn't allow port forwaring to Synology DSM
Hello, for a long period of time I had Synology DSM 115 connected to router. There were configuered a few ports via UPnP to access DSM from external source (3042 for access and some other like 8001,...
tomign
Hello,
at first I had upgraded to 1.0.9.18. Then to 1.0.9.20_1.2.28.
My port forwarding rules:
| 1 | 3042 | 3042 | 3042 | 192.168.1.3 |
| 2 | 80 | 80 | 80 | 192.168.1.3 |
| 3 | 8001 | 8001 | 8001 | 192.168.1.3 |
| 4 | 6281 | 6281 | 6281 | 192.168.1.3 |
| 5 | 5006 | 5006 | 5006 | 192.168.1.3 |
After it stopped working, I mean I couldn't access to DSM from external network, I have restarted the router and used DSM to auto configure via UPnP port forwarding. It didn't help, so I have turned of UPnP and added port forwarding manually, as listed above. It didn't help.
I turned on Remote management on port 8443. I have checked it from outside the network (via LTE connection) and it works OK.
I have upgraded to 1.0.9.18 and repeated above procedure. It didn't help.
I have upgraded to 1.0.9.20_1.2.28 and repeated above procedure. It didn't help.
There are no errors shown in logs or in router admin page. LED indicators shows everything is OK.
I have setup 192.168.1.3 to my DSM in both DSM settings and in router admin page, assigned this IP to DSM MAC.
Can you access your "my DSM" from within your LAN at the router's
WAN/Internet IP address? (That should be "mystaticip". Is it?)
Yes, I can access DMS via https://mystaticip:3042 from within my LAN.
