tomign
Jan 20, 2018Aspirant
R7000 after firmware upgrade doesn't allow port forwaring to Synology DSM
Hello, for a long period of time I had Synology DSM 115 connected to router. There were configuered a few ports via UPnP to access DSM from external source (3042 for access and some other like 8001,...
daktona
Jan 23, 2018Aspirant
I also have problems with the R7000 router and Synology DS116 NAS. I tried setting up ports manually, automatic via upnp, via Synology Ez internet and no luck connecting to outside only my local LAN.
With Ez internet it does recognize everything, it makes the port forwarding except it gives an error in Network Environment, (something with one or two routers.......) and still no outside connection. I can acces the nas inside my network without problems.
I have an PPPOE conection from ISP and it's direct cable to the router. Before this router I used an D-link DIR842 router and it worked perfectly. Any ideea what can I do ?
