HendrikB79
Mar 13, 2022Initiate
R7000 Amber LAN when Smart TV
My Sony Smart TV is connected through CAT6 wire (5G connection was not stable).
The LED on the connected LAN port is blinking orange, but Internet (i.e. Disney+) is working properly.
I have done some basic root cause tests but cannot find the issue.
Any thoughts on what's going on?
Nothings wrong. Most tv's are only 10/100mbps connections and not gigabit.
Red/amber indicates a 10/100mbps and not gigabit.
- HendrikB79InitiateThanks! That’s the only thing I did not check and you are richt. TV ethernet is Indeed 10/100mbps
