Cscholpp
Feb 06, 2021Aspirant
R7000 amber light when connected to Motorola MB7621 modem
Xfinity 200 MBps service. Connecting computer directly to router via Ethernet cable I get 240Mbps on Speedtest. When I connect the modem to the router (yellow port to yellow port), the router Internet...
Feb 06, 2021Guru - Experienced User
power off the modem and router. disconnect the coax cable from the modem and all devices from both. Wait 2 minutes.
Then connect coax back to the modem. power it on and wait a couple minutes for it to fully boot.
Then connect it to wan port on r7000.
power the router on and wait a couple minutes.
Try setup/usage.
