Cscholpp
Feb 06, 2021Aspirant
R7000 amber light when connected to Motorola MB7621 modem
Xfinity 200 MBps service. Connecting computer directly to router via Ethernet cable I get 240Mbps on Speedtest. When I connect the modem to the router (yellow port to yellow port), the router Internet...
sktn77a
Feb 06, 2021Virtuoso
"Connecting computer directly to router via Ethernet cable I get 240Mbps on Speedtest."
Do you mean connecting computer directly to the modem? Othwise, I can't figure out your post(?)
Feb 06, 2021Guru - Experienced User
What you're doing is powering off both the modem and the router. disconnect everything from both including coax from modem. then waiting 2 minutes.
You're giving you isp time to release the ip address it might have assigned prior.
then you connect the modem back to the coax and power it on.
Give it time to fully boot.
then connect the router to the modem.
lan port from the modem connects to wan port on router. ]
Then power the router on and give it a couple minutes to fully boot.
then try to setup the router.
