omoeller
Aug 18, 2015Guide
R7000 and bandwidth control
I am using my R7000 behind a DSL modem as LAN and WiFi router and since a couple of weeks I am recognising an odd behaviour - when one of the other clients connected to the R7000 is starting a downlo...
- Aug 19, 2015On an asymmetrical link, where the upload rate is a fraction of the download rate it’s possible to choke the network with upload data. So for example with a large TCP download where packets are acknowledged by the receiving computer then there can be a corresponding high upload of data, and if the upload rate limit is significantly lower that the download rate limit then the Internet connection can grind to a halt. The first few paragraphs of this .pdf might explain better than I can; http://www.sigcomm.org/sites/default/files/ccr/papers/2012/January/2096149-2096158.pdf
Babylon5
Aug 18, 2015NETGEAR Employee Retired
Is your DSL modem also a modem/router combo, and if so is it set to Bridged Mode? Can you say what kind of download causes the issue or is it any type of download?
omoeller
Aug 18, 2015Guide
I am using a AVM Fritzbox 7390 as DSL Modem - this is as modem/router combo and I need to check if it is set to Bridge mode - With regards to the type of download I think it does not really matter - I experienced this in all file download scenarios as well as streaming.
