chopin70
May 22, 2016Virtuoso
R7000 and latest beta 1.0.6.40_1.1.90 small cosmetic bug
Hi, I updated recently to 1.06.40. For now, it seems much more stable than previous 1.0.5 and 1.0.6.28 versions I still have it to run for a few days without reboot and under havy p2p load to se...
- May 24, 2016
Hi Chopin70,
Please check this official firmware for stability.
JamesGL
May 23, 2016NETGEAR Employee Retired
Hi Chopin70,
Are you using the R7000 for Arlo purposes? If not, you may try using the beta firmware v1.0.5.62.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-Beta-FW-1-0-5-62/m-p/1078114#M31145.
- chopin70May 24, 2016Virtuoso
I use it as a general purpose, no need to Arlo services. However, I upgraded to beta because I need the Android OpenVPN support not present in current stable 1.0.4.30 version
I had tested 1.0.5.48 and 1.0.6.28 in the past and they were very unstable in the long run with a heavy load
Is 1.0.5.40 just an Arlo stripped 1.0.6.40 firmware that will provide same stability?
Thanks again for your support.
