required_alias
Mar 05, 2023Guide
R7000 and mystery addresses
Have an R7000 members here helped me get running properly. Next question. I have 50+ devices. Have the MACs for all of them. Logging in to the router though a browser, Basic>Attached devices show...
Mar 07, 2023Guru - Experienced User
All have same MAC Address?
required_alias
Mar 07, 2023Guide
yup
- FURRYe38Mar 07, 2023Guru - Experienced User
So What if you set a IP address reservation for this device on the router, does it then keep and see the same IP address across the board?
What is this device?- required_aliasMar 07, 2023Guide
This gets more fun all the time. Smartthings hub
Now doesn't show up in Genie.
Accessing the router through my browser,
Advanced > Access Control shows x.x.x.14.
I wanted to make it a static address. went to Advanced>Setup>LAN setup>ADD
The hub doesn't show.
Back to Advanced > Access Control shows x.x.x.14.
This is quite frustrating. I get IP addresses bounce around, but showing up in one screen, but not the other is not making me happy.
As a reminder, my wife is in the same room on her iPad. That iPad has never shown in Genie or Access Control.
I now have 19 IP addresses showing in either Genie or my browser for which I have no device AND have 6 devices working properly that never show up.
What FW is loaded on the router?
Is the IP address for the router and DHCP IP address pool 192 or 10.something on the LAN side?
So you have SPC or Circle enabled on the router or via NH app?
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
