Mike_5's avatar
Mike_5
R7000 and Netgear Genie
I have a R7000 and I was using Netgear Genie on one of my PC's to monitor the network. That is/was a PC app. I know that I can see my network using routerlogin.net but it does not give me the views that I can see on Genie. Is there a place to download and install an app on my PC for Genie or whatever replaced it?
Mike
    Mike
    I believe you can still download it for Windows here:
    http://updates1.netgear.com/netgeargenie/update/NETGEARGenie-install.exe
    But I believe they (Netgear) are pushing to iOS and Android apps.
    Mike
