Jesus4me
Oct 08, 2017Aspirant
R7000 and Roku Ultra
We recently purchased within like a month ago. We were experiencing one channel BVOVN that the streaming was being interrupted in watching on the ROKU. So we recently did a hardwire with the ROKU t...
- Oct 12, 2017
My husband actually was searching the forums and found this secrete. Basically we lowered the bit rate, and on the Roku remote secrete panel using the remote. 5 times press the home button, then quickly 3 times back and 2 time forward buttons in sequence. At the bottom of that screen there was something about bugging we wanted it too and then set it the second number from the top f that screen. Once you do the bottom you will have to go back into that screen again and select cant do both at the same time. Out picture is still very good and it solved the freezing up all the time. Such a blessing
Jesus4me
Amber light on the router
William10a
Oct 08, 2017Master
Which lite is amber on the router if on the wired lan ports it means 10/100 mb connection white would be a 1gb connection the max speed the that one connection can work.
- Jesus4meOct 10, 2017Aspirant
Yes you are correct it will stay Amber its a higher speed.
Yesterday the issue with our ROKU and the Our router mentioned above. The problem is solved. Its
- ElaineMOct 12, 2017NETGEAR Employee Retired
Care to share the solution?
- Jesus4meOct 12, 2017Aspirant
